@egor.fedorov,
I have captured both a successful connection and a failed connection. Here are the steps I took.
- Booted the RPi router and waited for it to be ready.
- Booted ReachRS and waited for it to connect to the RPi hotspot.
- Rebooted the RPi router. When the router came back up ReachRS connected successfully (not typical).
- Rebooted the RPi router a second time. Again, when the router came back up ReachRS connected successfully (not typical).
- Rebooted the RPi router a third time. This time ReachRS failed to connect (typical).
On the third (failed) attempt the blue LED on ReachRS went from fast flashing to off (for about 10 sec) back to fast flashing. I’m pretty sure the off state does not occur when everything goes well.
From this point on ReachRS will not connect to any known networks and will not create a hotspot. The only way out it to reboot ReachRS.
From what I can tell from the log files it looks like WPA_supplicant crashes and doesn’t recover.
Timing
To make it easier to follow the log files I have listed the time of key events below:
04:26:21 - Boot Reach RS
04:26:59 - Reboot RPi x1 (success)
04:43:11 - Reboot RPi x2 (success)
04:45:27 - Reboot RPi x3 (fail)
04:48:20 - Shutdown ReachRS
The full logs can be downloaded from here.
I’ve listed the main parts below:
root@reach-rover[/]# journalctl -u wpa_supplicant_p2p_event.service --no-pager
– Logs begin at Tue 2017-10-31 04:26:11 UTC, end at Tue 2017-10-31 04:55:11 UTC. –
Oct 31 04:26:21 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:26:21 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:26:22 reach-rover wpa_cli[328]: Failed to connect to non-global ctrl_ifname: p2p-dev-wlan0 error: No such file or directory
Oct 31 04:26:22 reach-rover systemd[1]: wpa_supplicant_p2p_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:26:22 reach-rover systemd[1]: Unit wpa_supplicant_p2p_event.service entered failed state.
Oct 31 04:26:23 reach-rover systemd[1]: wpa_supplicant_p2p_event.service holdoff time over, scheduling restart.
Oct 31 04:26:23 reach-rover systemd[1]: Stopping Daemon to receive the wpa_supplicant event…
Oct 31 04:26:23 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:26:23 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:26:23 reach-rover systemd[1]: wpa_supplicant_p2p_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:26:23 reach-rover systemd[1]: Unit wpa_supplicant_p2p_event.service entered failed state.
Oct 31 04:26:23 reach-rover wpa_cli[332]: Failed to connect to non-global ctrl_ifname: p2p-dev-wlan0 error: No such file or directory
Oct 31 04:26:24 reach-rover systemd[1]: wpa_supplicant_p2p_event.service holdoff time over, scheduling restart.
Oct 31 04:26:24 reach-rover systemd[1]: Stopping Daemon to receive the wpa_supplicant event…
Oct 31 04:26:24 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:26:24 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:47:46 reach-rover systemd[1]: Stopping Daemon to receive the wpa_supplicant event…
Oct 31 04:47:48 reach-rover wpa_cli[357]: wpa_supplicant is terminating - stop monitoring
Oct 31 04:47:48 reach-rover wpa_cli[357]: eloop: could not process SIGINT or SIGTERM in two seconds. Looks like there
Oct 31 04:47:48 reach-rover wpa_cli[357]: is a bug that ends up in a busy loop that prevents clean shutdown.
Oct 31 04:47:48 reach-rover wpa_cli[357]: Killing program forcefully.
Oct 31 04:47:48 reach-rover systemd[1]: wpa_supplicant_p2p_event.service: main process exited, code=exited, status=1/FAILURE
Oct 31 04:47:48 reach-rover systemd[1]: Stopped Daemon to receive the wpa_supplicant event.
Oct 31 04:47:48 reach-rover systemd[1]: Unit wpa_supplicant_p2p_event.service entered failed state.
– Reboot –
Oct 31 04:48:14 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:48:14 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:48:14 reach-rover wpa_cli[328]: Failed to connect to non-global ctrl_ifname: p2p-dev-wlan0 error: No such file or directory
Oct 31 04:48:14 reach-rover systemd[1]: wpa_supplicant_p2p_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:48:14 reach-rover systemd[1]: Unit wpa_supplicant_p2p_event.service entered failed state.
Oct 31 04:48:15 reach-rover systemd[1]: wpa_supplicant_p2p_event.service holdoff time over, scheduling restart.
Oct 31 04:48:15 reach-rover systemd[1]: Stopping Daemon to receive the wpa_supplicant event…
Oct 31 04:48:15 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:48:15 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:48:15 reach-rover wpa_cli[334]: Failed to connect to non-global ctrl_ifname: p2p-dev-wlan0 error: No such file or directory
Oct 31 04:48:15 reach-rover systemd[1]: wpa_supplicant_p2p_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:48:15 reach-rover systemd[1]: Unit wpa_supplicant_p2p_event.service entered failed state.
Oct 31 04:48:16 reach-rover systemd[1]: wpa_supplicant_p2p_event.service holdoff time over, scheduling restart.
Oct 31 04:48:16 reach-rover systemd[1]: Stopping Daemon to receive the wpa_supplicant event…
Oct 31 04:48:16 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:48:16 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
root@reach-rover[/]# journalctl -u wpa_supplicant_wlan0_event.service --no-pager
– Logs begin at Tue 2017-10-31 04:26:11 UTC, end at Tue 2017-10-31 04:57:41 UTC. –
Oct 31 04:26:21 reach-rover wpa_cli[324]: Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
Oct 31 04:26:21 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:26:21 reach-rover systemd[1]: Unit wpa_supplicant_wlan0_event.service entered failed state.
Oct 31 04:26:23 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service holdoff time over, scheduling restart.
Oct 31 04:26:23 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:26:23 reach-rover systemd[1]: Unit wpa_supplicant_wlan0_event.service entered failed state.
Oct 31 04:26:23 reach-rover wpa_cli[334]: Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
Oct 31 04:26:24 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service holdoff time over, scheduling restart.
Oct 31 04:26:28 reach-rover wpa_cli[356]: event CONNECTED received from wpa_supplicant
Oct 31 04:26:28 reach-rover udhcpc[378]: udhcpc (v1.22.1) started
Oct 31 04:26:28 reach-rover wpa_cli[356]: udhcpc (v1.22.1) started
Oct 31 04:26:28 reach-rover udhcpc[378]: Sending discover…
Oct 31 04:26:28 reach-rover wpa_cli[356]: Sending discover…
Oct 31 04:26:28 reach-rover udhcpc[378]: Sending select for 192.168.50.2…
Oct 31 04:26:28 reach-rover wpa_cli[356]: Sending select for 192.168.50.2…
Oct 31 04:26:28 reach-rover udhcpc[378]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:26:28 reach-rover wpa_cli[356]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:26:28 reach-rover wpa_cli[356]: /etc/udhcpc.d/50default: Adding DNS 192.168.50.1
Oct 31 04:26:59 reach-rover wpa_cli[356]: event DISCONNECTED received from wpa_supplicant
Oct 31 04:26:59 reach-rover wpa_cli[356]: 399 root 2652 S udhcpc -i wlan0 -p /var/run/udhcpc-wlan0.pid -S
Oct 31 04:26:59 reach-rover wpa_cli[356]: rm: cannot remove ‘/var/run/udhcpc-wlan0.pid’: No such file or directory
Oct 31 04:28:05 reach-rover wpa_cli[356]: event CONNECTED received from wpa_supplicant
Oct 31 04:28:05 reach-rover udhcpc[510]: udhcpc (v1.22.1) started
Oct 31 04:28:05 reach-rover wpa_cli[356]: udhcpc (v1.22.1) started
Oct 31 04:28:05 reach-rover udhcpc[510]: Sending discover…
Oct 31 04:28:05 reach-rover wpa_cli[356]: Sending discover…
Oct 31 04:28:05 reach-rover udhcpc[510]: Sending select for 192.168.50.2…
Oct 31 04:28:05 reach-rover wpa_cli[356]: Sending select for 192.168.50.2…
Oct 31 04:28:05 reach-rover udhcpc[510]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:28:05 reach-rover wpa_cli[356]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:28:05 reach-rover wpa_cli[356]: /etc/udhcpc.d/50default: Adding DNS 192.168.50.1
Oct 31 04:43:11 reach-rover wpa_cli[356]: event DISCONNECTED received from wpa_supplicant
Oct 31 04:43:11 reach-rover wpa_cli[356]: 525 root 2652 S udhcpc -i wlan0 -p /var/run/udhcpc-wlan0.pid -S
Oct 31 04:44:12 reach-rover wpa_cli[356]: event CONNECTED received from wpa_supplicant
Oct 31 04:44:12 reach-rover udhcpc[699]: udhcpc (v1.22.1) started
Oct 31 04:44:12 reach-rover wpa_cli[356]: udhcpc (v1.22.1) started
Oct 31 04:44:12 reach-rover udhcpc[699]: Sending discover…
Oct 31 04:44:12 reach-rover wpa_cli[356]: Sending discover…
Oct 31 04:44:12 reach-rover udhcpc[699]: Sending select for 192.168.50.2…
Oct 31 04:44:12 reach-rover wpa_cli[356]: Sending select for 192.168.50.2…
Oct 31 04:44:12 reach-rover udhcpc[699]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:44:12 reach-rover wpa_cli[356]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:44:12 reach-rover wpa_cli[356]: /etc/udhcpc.d/50default: Adding DNS 192.168.50.1
Oct 31 04:45:27 reach-rover wpa_cli[356]: event DISCONNECTED received from wpa_supplicant
Oct 31 04:45:27 reach-rover wpa_cli[356]: 714 root 2652 S udhcpc -i wlan0 -p /var/run/udhcpc-wlan0.pid -S
Oct 31 04:45:27 reach-rover wpa_cli[356]: rm: cannot remove ‘/var/run/udhcpc-wlan0.pid’: No such file or directory
Oct 31 04:47:48 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service: main process exited, code=exited, status=1/FAILURE
Oct 31 04:47:48 reach-rover systemd[1]: Unit wpa_supplicant_wlan0_event.service entered failed state.
Oct 31 04:47:48 reach-rover wpa_cli[356]: wpa_supplicant is terminating - stop monitoring
Oct 31 04:47:48 reach-rover wpa_cli[356]: eloop: could not process SIGINT or SIGTERM in two seconds. Looks like there
Oct 31 04:47:48 reach-rover wpa_cli[356]: is a bug that ends up in a busy loop that prevents clean shutdown.
Oct 31 04:47:48 reach-rover wpa_cli[356]: Killing program forcefully.
– Reboot –
Oct 31 04:48:13 reach-rover systemd[1]: Starting Daemon to receive the wpa_supplicant event…
Oct 31 04:48:13 reach-rover systemd[1]: Started Daemon to receive the wpa_supplicant event.
Oct 31 04:48:13 reach-rover wpa_cli[324]: Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
Oct 31 04:48:13 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:48:13 reach-rover systemd[1]: Unit wpa_supplicant_wlan0_event.service entered failed state.
Oct 31 04:48:15 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service holdoff time over, scheduling restart.
Oct 31 04:48:15 reach-rover wpa_cli[332]: Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
Oct 31 04:48:15 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service: main process exited, code=exited, status=255/n/a
Oct 31 04:48:15 reach-rover systemd[1]: Unit wpa_supplicant_wlan0_event.service entered failed state.
Oct 31 04:48:16 reach-rover systemd[1]: wpa_supplicant_wlan0_event.service holdoff time over, scheduling restart.
Oct 31 04:48:20 reach-rover wpa_cli[358]: event CONNECTED received from wpa_supplicant
Oct 31 04:48:20 reach-rover udhcpc[380]: udhcpc (v1.22.1) started
Oct 31 04:48:20 reach-rover wpa_cli[358]: udhcpc (v1.22.1) started
Oct 31 04:48:20 reach-rover udhcpc[380]: Sending discover…
Oct 31 04:48:20 reach-rover wpa_cli[358]: Sending discover…
Oct 31 04:48:20 reach-rover udhcpc[380]: Sending select for 192.168.50.2…
Oct 31 04:48:20 reach-rover wpa_cli[358]: Sending select for 192.168.50.2…
Oct 31 04:48:20 reach-rover udhcpc[380]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:48:20 reach-rover wpa_cli[358]: Lease of 192.168.50.2 obtained, lease time 43200
Oct 31 04:48:20 reach-rover wpa_cli[358]: /etc/udhcpc.d/50default: Adding DNS 192.168.50.1
root@reach-rover[/]# journalctl -u wpa_supplicant.service --no-pager
– Logs begin at Tue 2017-10-31 04:26:11 UTC, end at Tue 2017-10-31 04:59:12 UTC. –
Oct 31 04:26:21 reach-rover systemd[1]: Starting WPA supplicant service…
Oct 31 04:26:22 reach-rover systemd[1]: Started WPA supplicant service.
Oct 31 04:47:46 reach-rover systemd[1]: Stopping WPA supplicant service…
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: Successfully initialized wpa_supplicant
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: Trying to associate with 11:22:33:44:55:66 (SSID=‘MySSID’ freq=2437 MHz)
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: Associated with 11:22:33:44:55:66
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: WPA: Key negotiation completed with 11:22:33:44:55:66 [PTK=CCMP GTK=CCMP]
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-CONNECTED - Connection to 11:22:33:44:55:66 completed (auth) [id=3 id_str=]
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-DISCONNECTED bssid=11:22:33:44:55:66 reason=2
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=3 ssid=“MySSID” auth_failures=1 duration=10
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-SSID-REENABLED id=3 ssid=“MySSID”
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: WPA: Group rekeying completed with 11:22:33:44:55:66 [GTK=CCMP]
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=11:22:33:44:55:66 status_code=1
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: Retrying assoc: 1
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-DISCONNECTED bssid=11:22:33:44:55:66 reason=3 locally_generated=1
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: Retrying assoc: 2
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=3 ssid=“MySSID” auth_failures=2 duration=20
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
Oct 31 04:47:46 reach-rover wpa_supplicant[322]: wlan0: CTRL-EVENT-TERMINATING
Oct 31 04:47:48 reach-rover systemd[1]: Stopped WPA supplicant service.
– Reboot –
Oct 31 04:48:13 reach-rover systemd[1]: Starting WPA supplicant service…
Oct 31 04:48:14 reach-rover systemd[1]: Started WPA supplicant service.
