Navio+ GPS doesn’t show any lock , and in mission planner it shows gpsstaus=0
even though ublox centre shows GPS lock. I run Ublox centre with link to Navio+ through the
ublox-spi-to-tcp utility in pi. I use pi3.
I have even tried external GPSs with -C option and -E option but this didn’t work too.
I cant think of something else to do.
I am using the Emlid Raspbian Image for Navio2/Navio+ (emlid-raspbian-20160408) image
The arducopter command i send is sudo ArduCopter-quad -A udp:192.168.0.144:14550
strange result now
seems to work as it shows on image … now i have a location , hdop 2.9 on map (not expected good where i put the gps) but also 99.999 on the left
sats:6
but gpsstatus is still 0 !!! . What do you think about it ?
Could you please enable DisarmedLogging in parameters. Restart and send us a log. It seems taht the issue has gone away, though. I do see GPS: 3D Fix on your screenshot.
