Problem RS2 RTK data to Mission Planner by Inject Tool
I am trying to inject RS2 data intro MissionPlanner following the steps from: ArduPilot Integration | RTK Modules
I reviewed many times the setup details but always received the error message (“No connection could be made because the target machine actively refuse…”):
I reviewed the IP and Port; the RS2 hotspot mode (I can establish a connection by the laptop, entry to Emlid Setup by Brower using the IP):
The RS2 setup is as follow (RS2 firmware 32.2):
I tried with 2 different laptops, so I would appreciate any clue.
Hi @jpgayoso,
Have you tried to disable the firewall on your PC? It might be possible that it prevents the connection with the device.
Hi Ruth
I tried turn off the firewall, it didn’t works. But I thought in “Restore the Initial Setting” option and Voilà, it is working now. I don’t know which setting was wrong…thank you.
That’s great to hear! I’m glad you were able to figure it out.
