I have been using the RS3 successfully for about 6 months but over the last 30 days I have not been able to keep a solid connection between my android phone and the RS3. On and off, I can connect through the app or the IP address but it doesn’t last. I have been trouble shooting on and off for some time and I think I am ready to perform a factory reset. My RS3 was updated to firmware version 33 about 30 days ago. Can you help me perform the reset? Other suggestions?
Have you tried another mobile phone to first confirm if the issue is the phone or RS3?
Could it be your phone has been updated or just need a reboot too.
Or maybe a power setting has been changed, memory full or not not enough free disk space.
Also check the app has all the necessary approvals to run.
Also, is the BLE connection stable?
Hi @wgardner, and welcome to the Community Forum!
We have not received any reports of this behavior with the most recent firmware versions, so I would like to try and troubleshoot this first before we look at reflashing as an option.
It would be a good idea to first make sure that battery optimization is disabled for the Emlid Flow app in your phone’s settings. Also, if you are connected to the RS3’s hotspot, please ensure that your phone’s mobile data is turned off. It can happen that the phone prioritizes its own mobile data for internet connection over the Reach hotspot, which can cause such. Let me know if this helps.
As an alternative, you can connect to the RS3 via Bluetooth in the app. For this, you simply need to turn on Bluetooth on your phone, and you will see the RS3 with the Bluetooth icon within the app.
Good morning. More background: Originally, 2 of us connected to the unit, back and forth and it worked fine over the entire summer of 2025. In December, the CC expired and our data plan stopped. I restarted the plan but had trouble connecting to base unit on rooftop not far away. I was only able to work through the Bluetooth connection to my phone for error correction. I got a new Sim card. In trouble shooting, T-Mobile and the app do show data transmission via the RS3 sim card. During the troubleshooting, I have generally lost the ability to even connect through BT to my phone reliably. I have rebooted everything many times and can make intermittent connections to my phone, even after disabling my phone’s ability to hunt for other wifi. Yesterday, I was able to connect to the unit with IP address and verify a few things but just an hour or so later, I could no longer make that connection. We have tried the other phone with similar results = unable to connect via the sim card and only temporarily via BT to the cell phone. Before continuing, I do want to try one more time using my co-workers phone. Standby and I will report the results as soon as we can make the attempt. Thanks so much for the responses
Hi Wayne,
Thank you for the detailed response. What you describe is unusual, and I would like to investigate it thoroughly. For this, we will need to go through some troubleshooting steps together, and I think it will be better if we continue via PM, as sensitive information might be involved at some point.
