My rover is not receiving correction from the base by NTRIP Caster, I mean the settings are right, when I’m using Lora, I have not any trouble to work.
I’m working with REACH RS2.
Hello.
I had a similar issue a while back. I think there was an issue with the mount point and my caster account. So it may be worth opening a new mount point in the caster and starting from the beginning. Or try to use the full website IP address for the rover mount point, that seemed to fix things for me. You can use a port style address or the web address. Even though they are the same mount point it jammed until I used the other version.
Also make sure the base and rover are getting internet. It sounds simple but I’ve spent a while problem solving before realising the WiFi connection wasn’t one with internet.
Hi @jofemo60,
Could you please tell me more about the issue? Do you have a stable internet connection?
What do you see in Emlid Flow? Is it stuck in Single, or do you get at least a Float?
Please generate the Full System Report and send it to us. As it contains sensitive information, you can email us at support@emlid.com. We’ll investigate.
Thank you!
