Hello my first question and its a newbie question. Does anyone have any experience using a rs2+ as a base and rs3 rover ,importing dfx files and doing stakeout. What can be expected under very good conditions as far as horizonal and vertical precision, thanks for any help.
Hi Jeff,
Don’t worry, such questions are very important to understand, and we all need to start somewhere.
If you want to know the precision of your rover, there are many variables to consider. First, I would recommend that you check the specifications of our devices, which you can find here. If we take your example and the environmental conditions are good, it mostly depends on the base setup.
- You can find more information on how to set it up here.
- If you collected the points you want to stake out in the same setup, it is recommended that you set up your base at the same place you set it up last time.
If you follow these steps, your setup can achieve a few cms of accuracy.
If you need tips or have any questions about DFX or stakeout, you can find them here.
welcome @csaba.galli
