Ppp data process
Hi I wanted to know that how can i process the logged data by ppp. Since im from Nepal i want to process the ppp data in default setting since only default allows to record data by all satellites. If i can process the default setting data i may achieve more accuracy since it records data from all satellite.
Hi
You may try PENTAP PPP
Hi Bibhusan,
Do I understand correctly that you meant that the default setting here is to use all the satellite constellations (GPS, GLONASS, Galileo, QZSS, and Beidou)?
So far, I just knew OPUS beta, which includes all the satellite constellations. Unfortunately, it’s still in beta and works only for the US area.
Hopefully, others can give some suggestions.
Thank you. I hope it will be available in all region.
