Hi Mates,
I’m trying to process GPS RINEX data using RTKLIB by using the PPP- RTK method. I found in their forum it mentioned that PPP-RTK is the PPP-AR module, though it is experimental. Can any of you give me some clue that how this function works? As in PPP Static mode, there will not be possible to input base station data, then how would CORS network information be used in this work flow?
Thanks a lot.
Cheers,
Tim
