Hello,
I intend to use Reach RS in the mode highlighted below:
I have some questions about the differences in at which point in time you process your data in the survey workflow… Here I present two scenarios, which show how I envisage Reach RS working:
Scenario 1:
- Set up base over unknown point
- Leave base for an hour
- Set up rover
- Collect point measurements with rover
- Pack kit away
- Obtain base coordinates using my chosen RINEX service
- Use PPK to process my points and obtain ~7mm accuracy points in a real coordinate system (e.g. British National Grid).
Scenario 2:
- Pack kit away
- Set up base over known point
- Pack kit away
- Enjoy my already corrected points with 7mm accuracy in a real coordinate systems (e.g. British National Grid).
Can both of these scenarios be performed with 2 Reach RS units?
If so, do both produce the same accuracy in the points collected with the rover?
If not, which bit doesn’t work?
Some clarification here would be much appreciated!
Many thanks
James
