Can someone points me to a tutorial or a topic to use PPK based on static survey made with a single reach rover module (rover) ?
We don’t want to proceed PPK on raw log file but post process accurate location of statiic survey of points based on external information from a public bases network (Walocrs, in Wallonia).
There is a lot of info about how to process ppk of raw log but not on specific survey points.
When not doing RTK, but instead, collecting the raw logs for post processing of static points (PPS), this is the basic workflow that I have used:
TL;DR --> capture a separate log file for each point, which lets you post-process each point separately.
In the field:
Place base station and turn on raw log
Place rover on point 1 and turn on raw log
write point name and log start time in notebook
consider taking a picture of the point with your camera
when finished ( 2min, 10min, 30min, 24hrs, etc.), turn off raw log
Move rover to point 2 and turn on raw log
when finished, turn off raw log
Repeat until all points collected
Shut down base station
Back at the office:
Download the raw log files from base and rover.
Convert rover raw log file for point 1 into RINEX
Append point name to the RINEX file(s) or place in folder named ‘point 1’
Note the precise start and end time of the log
Convert rover raw log file for point 2 into RINEX
Append point name to the RINEX file(s) or place in folder named ‘point 2’
Repeat until all rover logs are converted
Now, convert base raw log file into RINEX
restrict the conversion between the start and end times from point 1
append the file name with “point 1” or place in the folder for the point 1
Again, convert base raw log file into RINEX
this time, restrict the conversion between the start and end times from point 2
append the file name with “point 2” or place in the folder for the point 2
Repeat, until a base RINEX file is created for each point.
Now post-process the RINEX files
Rover point 1 with Base point 1
Rover point 2 with Base point 2
Repeat until all files are post-processed
Finished!
*note: If your base log is quite small, then you might consider processing the whole log instead of splitting it up. The reason for splitting it up is that large logs files can take a lot of time to post-process and also could cause an insufficient memory error during post-processing.
We understand this workflow is far from perfect. RINEX events for surveying are in our roadmap and we will start working on this feature very soon indeed.
