Hi, i PP my Surveyed data i made my .pos file and i made saved my way points, all my 58 ppk way points are recorded in single file log, then after next day i open rtk plot , open my .pos file and importing my saved waypoints it appears my way points are out of position as what i saved, any one can help on this , thanks.
Hi @franzanne27,
The first thought that came to my mind was to check the Base position settings for PPK. By default, the RINEX Header position is chosen. But you need to use exactly the same position you used in RTK. Have you tried that?
Also, I see you work with RTKLib. Have you heard about Emlid Studio? This is our new app for post-processing with a way more friendly interface
