PPK processing return empty events.pos file
After initial processing before geotaging, the output events.pos file returns empty, requesting a 0 number of image for geotagging. I have uploaded the files here to see if I can get help with this
Hi @babalugos,
Welcome to the community!
What’s your setup? Do you use a DJI drone, or do you use a custom setup with M2? If the former, you need the MRK file to generate the events.pos file.
If the latter, the time marks are saved in the RINEX observation file, which will be used to interpolate the events.
I use a DJI Phantom 4 Pro DRONE with X5 PPK Kit for DJI Phantom 4 series
I see. I checked the information about this PPK module, and the time marks should be saved in the RINEX logs. If no events were generated during post-processing, then it’s highly likely that the PPK module didn’t record the time marks whenever the camera was triggered.
I suggest checking your setup or contacting the manufacturer to understand why the time marks are not recorded.
