PPK Height POS file
I ran a PPK project using 2 Leica antenna. I uploaded both rover and base, Emlid Studios said it recognized the antenna type and would apply the correct offsets. Everything seems fine. Good fixed solutions. My only question is: in the POS file is the ellipsoidal height to the ARP or the Phase Center?
I am under the impression it is to the ARP since Emlid Studios recognized and new what antenna I was using.
Thanks.
It should always be ARP. The Rinex file should contain your antenna phase center offset.
Hi @snillor999,
Since Emlid Studio recognizes the antenna type, the height in the .pos file will be the ARP, as @Zaz5400 also mentioned.
Meanwhile, if you specify the measured height as below, then it will be the point on the ground.
Thanks for claritying. I thought that was way it worked. And I was using a 0 antenna (measured) height.
