When logging raw on the RS2+ for a PPK drone survey, what happens if your survey takes longer, or crosses over the hour log file that Emlid Flow produces?
In the Logging → Common Settings section, what is the Split Logs Interval set at? Normally by default it should be split at 24h and you should get continous files of several hours.
I would check that setting if I were you.
Thanks,
It always used to be a continuous log. Maybe since an update it has set it to 1hr files.
I’ll check the settings section.
Hi @tony1
Sorry for the silence here!
I’ve checked that for the latest update. Logging interval will be set up to 24 hours as the default value.
I agree with @Gabriel_C about checking the logging interval to ensure continuous logs.
Have you checked the settings? Let me know how it is going.
