I have an instrument that can get position from a GPS, reading NMEA string (GGA and GST).
When connected in NTRIP the NMEA file is generate from the Reach, so no problems at all.
I would like to be able to do the same with no NTRIP connection, using PPK.
After getting a pos file is there an automated way to generate a NMEA sequence with GGA and GST?
Thanks in advance,
Massimo
In settings in Emlid Studio, you can choose the NMEA0183 in Solution format. After the file is processed you will get a file in NMEA format.
Can you tell me more about your project? Do you use any 3rd-party software to work with NMEA files after?
UPD: Fixed the answer to avoid confusion
I have a 3rd party instrument (Geoslam Horizon) that can correct the trajectory of the scanner using the NMEA strings of an attached GPS.
From RS2 (connected with Ntrip to a correction net) I can easily save the NMEA strings while scanning, and post process the job with the localisation informations. The software asks for GGA and GST sentences.
I was wondering if in case of absent NTRIP connection I might be able to use the pos file generated in ppk mode and covert it to the desired format.
Looking at the pos file I guess a conversion is possible, but I’m wondering if it has already been done.
Thanks,
Massimo
Sorry for the confusion, in settings in Emlid Studio, you can choose the NMEA0183 in Solution format. After the file is processed, you will get a file in NMEA format. Will that work for you?
I also fixed the answer to my previous post.
Thanks!
I’ll test it.
Cheers,
Massimo
