we are doing ppk flights with drone and we have some doubts.
so far the results are very good, but at the time of postprocessing we have a problem with the rinex header.
To get the position of my base I use ntrip corrections until I get a fixed position. Once I have a two-minute average fix, we start the logging of the raw data.
The problem is that when I postprocess the data in RTKLIB to be able to obtain accurate data, I have to enter the base position manually (I always take captures) instead if I use the rinex header of my base I always get errors of quite a few meters.
does anyone know how to make my rinex of my base have the header correctly?
the truth is that I don’t know why … but I always had the feeling that if I start the logs in fix my results will be more precise. false intuition probably …
