Is the Navio power module absolutely necessary to power the Navio+ board ? Would for instance an external BEC equipped with a micro USB connector work ?
I know the battery voltage sensing would not be available anymore, but is that all that would be lost ?
Hi! Navio+ can be powered by a BEC connected to the servo rail (no need for microusb).
Keep the voltage in 4.8-5.3 range. Voltage and current sensing would not be available, but that’s all.
