I can’t power my 3dr radio using the USB port
I’m powering my reach via the DF13 port, using a Lipo battery, the reach powers up just fine, but when I connect the 3dr radio viaUSB port it dosen’t power up. The radio is working fine, I have tried powering it up with my computer and it works.
I’m using reach image 2.3 and reachview app v2.1.3
I have the same issue connecting the radios via USB and the radios led did not turn on. I tried connecting the radios to my laptop and they work fine. I have changed the radios and the problem persist.
@luccatiel if you want to connect USB device to Reach then you should plug the OTG cable in the microUSB port on Reach, not on 3DR radio (OTG cable is the short one). That’s the only way Reach would detect the OTG mode correctly and provide the power.
