Hey there, I have read many times, that you need more power for LTE modules, but if possible I would like to build some USB cable that is powered by the BEC, instead of the Raspberry. How can I do that and what has to be soldered to where?
Thank you
Javamaster10000
robertb
(Baumgartner)
March 18, 2016, 3:58pm
2
Hi.
But anyway you have to connect the LTE module USB into your Raspberry for “data” connection, so it’s easier.
You don’t need a “USB cable powered”, you can buy a powered USB hub if you don’t want to solder direct into your raspberry.
But again , the jumper is only 2 wires, really light, the powered hub …not.
But could I also just cut the power wires on the usb cable, and connect them to the jumper?
robertb
(Baumgartner)
March 19, 2016, 12:01am
4
yes, but you have to do for each device.
more work
and not good idea cut usb cables
Okay, so I will solder the raspberry. What should I solder where?
robertb
(Baumgartner)
March 28, 2016, 11:39am
6
I followed this step by step from uavmatrix.com
But I did because I have USB Camera AND Modem LTE at the same time, only the modem works fine alone.
