Hi Guys
I have got my Navio2 working great on my HexaCopter.
I am using a 4S 5000Mha Battery. I am powering the board via the power module. The voltage reported was very close to correct using the default divider of 10. I measure with my multi-meter and got a more exact one of 11.05. The current how ever seemed to be under reading massively, i used a current clamp from work over one of the battery wires and tried calibrating the Ampere per volt value it would seem 150 give me realistic results. I will try powering the copter form a bench supply with a multi-meter in series and confirming this ratio next week but was just wondering if i am doing something silly or if this is a ratio is more or less expected. it almost feel like this is factor of 10 out.
And advice or input on what other are using for these 2 values would be greatly appreciated.
Cheers
