Can I use the “power module”
http://www.emlid.com/shop/power-module/
and a LiPO 4S to power Reach?
Comparing the docs images
and
and the red wire in the DF13 of the “power module”
it seems the red wire are inverted .
Can you confirm?
Gianmarco
Hi Gianmarco,
Sorry there is a mistake on the picture, red wire should be on the right. The pinout is correct. If you remove all wires except for those on the sides of connector (pin1 and pin6) you can power Reach from the power module.
Thank you.
