HY guys
I need to post processing a static observation (5 hours) but I have the rinex of base station splitted per hour (i mean one file per each hour) so I tried to insert the * in the field RINEX OBS of base station but I received an error
can you help me ?
thx
Francesco
wizprod
(Christian Grüner)
September 3, 2018, 11:40am
2
You need to decompress the files, so they are in .XXo form.
@Francesco_sisani , did @wizprod advice helped you resolve the problem?
Hi
I unzipped but no .XXo form but .d
so what I have to do ?
With the normal version of rtklib If I put * character it works
Thx
TB_RTK
September 15, 2018, 6:18am
8
When unzipped like you have done above, use the .18d files
d=observation files.
Sorry …
I don’t understand …
I put * before .18d it doesn’t work
I select all files … it doesn’t work
What is the correct workflow to read and process all .18d files ?
or the issue is related to the version of rinex of base station
thx
Francesco
TB_RTK
September 17, 2018, 8:37am
11
Also, try putting all unzipped .18d only files in one folder
Hy guys
on the left RTKPOST by Emlid (not works) on the rigth the normal version (works)
I hope this can hlep
Francesco
TB_RTK
September 17, 2018, 8:59am
13
The files are not the same in the Emlid version
Did you try deleting the RTKpost.ini (for the Emlid version) file before running post?
Hi @Francesco_sisani ,
Can I ask you to share archived 18.d.Z logs from the first post so that I can provide you with step-by-step instruction?
You can send them with DM.
Thanks.
Hi
how can share the files because size is 50mb
thx
Francesco
@Francesco_sisani , you can download it on Dropbox or Google Drive and share a link with me.
master are base stations rinex
raw is the raw ulbox data
thx
Francesco
Can I ask you to send me your config file which you use to process in original RTKLIB version?
Thanks.
To close this question, I need to confirm that it’s not possible to process all RINEX hourly logs at once in Emlid RTKLIB v2.4.3.
You can make one log from them or process each hour separately.
We’ll add this function to our to-do list.
Thanks for the report.
system
(system)
Closed
February 15, 2019, 4:38pm
23
