mgsg
July 29, 2019, 4:48pm
#1
Has anyone used Topcon RINEX files as a base station to post-process their Reach data? Our local CORS station is down for the foreseeable future and we’re trying to post-process using a Topcon hyperlite.
Here’s what my rtkpost looks like:
And what the rtkpost positions option looks like:
Here’s my Reach+ files:
That shouldn’t be a problem. Looks like you’ve got some bad Glonass satellites. Maybe recalc without Glonass?
What are your values of float vs rtk in rtkplot? It is at the bottom.
mgsg
July 29, 2019, 6:26pm
#3
Everything is Q5:
when reprocessed with glonass as OFF
Should this one be 19n? I deal with the track files in what I do so someone else who does PPK survey points will probably have to chime in.
mgsg
July 29, 2019, 8:38pm
#5
I’ve tried using the 19n file before, I was just using the 19g to see if it helped.
Where are you located? In our system the 19g is the Glonass. Have you tried using the rover NAV?
mgsg
July 29, 2019, 8:57pm
#7
I’m in central Pennsylvania. It doesn’t seem to matter which nav I use, still Q5 all the way.
Could you share your raw files? I’ll take a look and the next person through would probably have asked as well.
mgsg
July 30, 2019, 1:44pm
#11
I’ve uploaded them to drive since I can’t upload attachments…
chascoadmin
(Michael Lambert)
July 30, 2019, 4:24pm
#12
Got it. I will take a look in a little bit.
Zinou
(Zinedine)
July 30, 2019, 6:21pm
#13
Here I have got 99.3 % Fixed
mgsg
July 30, 2019, 6:45pm
#14
Wow, that looks great. I’ve tried to replicate the settings the best I could, getting a bit closer but still no fix:
Here’s my current settings, how did you get the .19O and .19P files? Am I on a significantly different version?
Thanks though, this helps quite a bit.
Zinou
(Zinedine)
July 30, 2019, 6:53pm
#15
For height we need antenna height of course…
To get a P file you use RTCONV like that
mgsg
July 30, 2019, 7:28pm
#16
Thanks! the antenna height should be 1.43m. I’m able to get the same file extensions, but still no fix.
Could the issue be with my base position in rtkpost?
mgsg
July 30, 2019, 8:10pm
#18
Thank you so much! Using the newer version I was able to get a fix and everything worked properly. I think some of the issue may have been that I was trying to run rtklib via wine in Ubuntu, but on windows the newer version worked well. Thanks for all the help!
system
(system)
closed
November 7, 2019, 8:10pm
#19
