I have ReachView version: v0.4.9 and Reach image version: v1.2
I’m trying to Post Process GLONASS + GPS in RTKPOST, does anyone know how? I’m using two receivers with both in single static mode with the u-blox configuration file set on: GPS_GLONASS_5Hz
In RTKPLOT both the “R” and “G” satellites show up in the List of satellites visible with good data recorded, however the “R” ones don’t show up in the Sky Plot, only the “G” ones do.
For example I was able to log 7 usable “R” satellites and 7 usable “G” satellites the other day. I get a good fix of 1 mm, but when I post process again and exclude all the “G” satellite numbers just to see if GLONASS is being used or not I get Q=0. This must mean only GPS is being used. Is there a setting to turn on in RTKPOST that I don’t know about to allow the “R” GLONASS data to be read properly?
Anybody know how to solve this? Thank You.
