Hi everyone,
Hope someone can help me with my problem…
I performed a PPK survey. Unfortunately for Base logging i recorded the position instead of the raw data logging, which i only discovered when i was about to process it through Emlid Studio.
Is there any way to recover or obtain raw logs from the position data i had recorded.
Unless you had either UBX or UbX+Rinex, You are likely out of luck. When you say position data, do you mean points from RV3? That data cannot be submitted for PPK. Only raw logged data will work for PPK.
By any chance, are there any NTRIP stations near your survey site?
Even if you didn’t record base’s log, there was a chance that you could request the raw data log from NTRIP station. If you use Reach RS+, the distance to the nearest station shouldn’t exceed 30 kilometers.
To avoid such cases, I’d recommend automatic start of logging when the receiver is turned on. You can enable this toggle as shown in the screenshot below.
