What is the difference between position streaming and logging? Can i send base position to rover via streaming or is all the information already in the base correction file on the rover?thanks.
Hi @mabara,
Position streaming is the ability of the Reach receiver to send its position data using different formats. For example, you can configure Reach to stream its position via Bluetooth in NMEA format.
The logging option allows you to record the files with observation data (RINEX, UBX) or position data (LLH). Files with observation data can be used in post-processing.
The rover receives all the necessary information from the base corrections to calculate a fixed solution in real time. You don’t need to send the rover position to the base.
