I have an rtk setup with m2 as base and rs2 as rover. I turned the bluetooth on the rs2 under settings of reachview 3 to output positions in nmea format. Is the position outputted through bluetooth the corrected data or the uncorrected data from the rover?
NMEA from bluetooth will be in the solution you see from the status window of your Reach unit.
So for your case, if you see FIX in status windows, FIXed solution in the NMEA data on you rover (Hence corrected data)
