I am having the same issue. Numbers are changed to sequential starting from 1.
Also, both import and export CSV(PENZD) is not working correctly.
You may need to add a simple text import and export if you continue to have CSV coding problems.
Hi @alagha,
Please check that your setup and workflow are as described below. If it doesn’t help, please share the CSV file with me, and I’ll look into how we can make it work:
The app is updated to the latest version
You import the file as CSV, not CSV(PENZD)
The column with the point names is called Name
The file is in UTF-8 without BOM encoding. BOM encoding is rare in CSV, so it shouldn’t normally affect the import. But we keep an eye on such cases and look into the options for the future.
Which difficulties do you face with CSV(PENZD)?
