Well at least there’s a silver lining. This kind of thing (and others from different manufacturers) is one of the reasons our control is in to 10K’s. With Flow in particular because there was no layering we had to create separate projects for each utility line of each scope. Have you noticed if you bring in a second wave of points that it tries to renumber them back to 1 or does it pick up from the last number existing?
Florian, we checked your file with the devs. Seems that your CSV is in UTF-8 with BOM encoding. Because of that, there are some additional symbols at the beginning of the file, and the app can’t read the names of the points correctly. So it sets them automatically.
We’ve changed the encoding to UTF-8, and it started to work fine. Here is a reformatted file: guiana_import_utf8.zip (885 Bytes)
