Hi all,
I have been having a problem with my APP when taking points from a field survey.
I have taken 500 points using NTRIP, each for 5 seconds. The application is separating the measurements into 4 points( or is quadrupling them) instead of delivering a single piece of data.
Additionally I have a malfunction with the descriptions, I cannot change them if I edit them in the main screen, the change is not stored and continues with the previous description. I discovered that to remedy the case, I must enter the list of points and edit the last point stored in RTK applying the change of descriptor and after that the application does continue with the new descriptor.
I have only taken points as usual work
Has anyone else seen this problem?
**Firmware image its 31.8 and Emlid Flow version is 9.12 (subcription).
Im using Samsung S23+
One UI 6.0, Android V14
