However i am unsure what makes Galaxy device different from all other device like reach?
Questions:
Can one power the reach by POE Power over Ethernet AND data connect to it?
Do POE-USB adapters forward the power to the reach?
If so what will work? Link?
Seems like some models like this hub could do the trick.
Judging by description It should:
Provide power to a Reach module
Act as a USB hub
Act as a USB-Ethernet adapter - BUT it is not guaranteed that Reach has a driver for the USB-ETH chip used in it, if it’s not some universal USB class, should be tested.
Other solution would be to keep Reach inside and use 40m antenna cable with an amplifier.
