We’ve added support for PNEZD CSV import/export in Emlid Flow and Emlid Flow 360, making it easier to work with files structured as Point, Northing, Easting, Elevation, and Code. This update is especially useful for our US users, as PNEZD is a widely used format in the region.
One thing that is still lacking now is that it still does not export ’ The “D” description’ portion. Unless I am missing something.
For me to get a full usable export, I must export all columns, then edit the export file using Excell to remove all the uneeded columns, and include the “Description” into the last column, to achieve a true PNEZD csv file. One which I could then import into every standard CAD application.
At this point, I have concluded that feature is not enabled so as to force users to subscribe monthly and use Codes, which I do not use and have no intention ever. I use Descriptions rather than Codes, as the features I collect have wildly varying identities and it is much more efficient and convenient to improvise its description upon discovering and identifying a particular object.
I would rather pay an upfront cost for the most fundamental basic, industry standard features being able to import and export a true PNEZD csv file
no headers
P,N,E,Z,D
P,N,E,Z,D
P,N,E,Z,D
P,N,E,Z,D
P,N,E,Z,D
nothing else. Is that really too much to ask for?
Its surely what I thought I would be getting when I purchased this.
Am I missing something?
Thanks for your feedback and for explaining your use case.
I’ve looked into it, and you’re absolutely right that the current export format doesn’t include the “D” description by default. After reviewing this feature, we found that using codes may be a better fit for integration with external software like AutoCAD. However, I completely understand how this adds extra steps to your specific process.
I’ve shared your thoughts with the team so they’re aware of this need. We know how important flexibility is for different workflows. There’s no ETA I can share right now, but I’ll be sure to keep you posted on any updates.
Here is another critical deal breaking issue. When you import a PNEZD file into a survey project, that import will automatically renumber your point numbers starting at 1. Doesnt matter that I very specifically created the points starting at 200, and that I already have existing points starting at 1.
So now I have different points with the same point numbers. Now I have two sets of points labeled 1,2,3,4,5,6,7,8,… How is it that it refuses to identify and use the particular point number as I created it. Do I have to manually enter all of my stakeout points, so that I do not overwrite my existing points? Is there some other work around? And why can I not simply import this as it is created. What am I missing?
I tested it but couldn’t reproduce the issue with renumbering points. How are you importing the PNEZD file via Emlid Flow 360 or the Emlid Flow app? If it’s the app, which version are you using, and what’s your phone’s OS?
These details will help me look into this further.
