We have Purchase the Reach M+ and planning to install it with Pixhawk 2.1.
We have an onboard GPS Here+ for navigation and planning to install the M+ on GPS 2 for PPK.
Is this correct?
If this topic already been discuss. Please point me on te right thread. will be testing the system soon.
Thank you. Already check that. It does not show an onboard gps on gps1 port. That is why im verifying. Im familiar with the set up. Just want to clarify that the reach m+ will have an independent job getting rinex data, event triggering.
That’s how I read the documentation, yes. And why wouldn’t you ? RTK will give centimeter level GNSS navigation, where as the built-in will give you meters.
We are flying cross country. PPK is our solution. RTK is limited with this application. When signal cuts off even using rfd900 radio accuracy is lost asfaik.
