I have just received my navio2 installed it on my Raspberry Pi3. I installed the Emlid image and rebooted the Pi. I am not able to ping or connect to my home LAN.
I had used the Raspian image before while testing the Pi and it connected to the LAN with no problems. The Pi3 has wifi on board. Does the Emlid image support that?. Any help would be appreciated.
I have the raspberry pi3 and attached the Navio2 to it. The Raspberry pi3 has on-board wireless (no dongle needed)
Before I attached the Navio2 I was able to test the Raspberry with the Raspian image and it connected fine to my wifi which is IPv4.
Then I re-imaged the card with the Emlid image and installed and booted my Raspberry. It boots fine but I see errors when it tries to do a sudo apt-update command and I do not see it on my network.
Last night I attached an ethernet cable to the Raspberry and my router and it was able to get online and do the updates, but if I remove the ethernet cable it still will connect to the wifi.
It is very similar situation to this, but I am not sure how it was resolved.
I was also able to complete this configuration and reboot and it is in the code now.
Configuring Wi-Fi access
Raspberry Pi3 has an internal Wi-Fi module, while Raspberry Pi2 requires an external USB Wi-Fi dongle. An extensive list of supported dongles is available here.
Wi-Fi networks can be configured by editing the /boot/wpa_supplicant.conf file located on SD card. To add your network simply add the following lines to it:
OK so yor advice about including the “quotes” was important, but it did not solve the problem. So I imaged a Raspian image and compared the files. The code at the bottom key_mgmt=WPA-PSK needed to be added. I think I am good now, but the documentation needs to be updated for those of us who are not coders.
