Hi, when i am connected to the hot spot created in a mobile phone, i can see the rover unit, but as soon as i can see the satellite chart, the bars disappears, all of them, the grey and the color ones.
Also, when trying to connect yo the ntrip server, it prompts an error in connection, but if i make it trough the local WiFi, it connects yo the ntrip server.
Sorry to hijack the thread but that is similar to the issues that I have been having in the post below. I can get it to work through local wifi network, but through the onboard cell modem I can’t get ntrip to work.
Are satellites showed correctly when Reach is in hotspot mode and you connect your phone to it?
Could you replicate the issue and record raw data and position logs for 5-10 minutes and then send it to me? I’d like to check whether it’s displaying issue or Reach doesn’t see satellites at all.
I’ve also noticed that both videos and system report indicates that there is no SIM card inserted at all. May I ask you to share a photo of SIM card inserted in the slot so we can make sure everything is fine with it?
Yes i have succesfully connected the RS2 unit to the phone hotspot, but as soon as i enter to the Status screen, the satellite bars appear and then dissapear, like in the video.
Yes, i have some data, there are not many minutes, but i think is enough.
There are two files, the one named “Rover_201909122206_RINEX-3_00_SIM.zip”, is when i connected the rover with the sim card. The issue there is that the base satellites switch from one constellation to another not getting fix. (Video attached)
The other file named “Rover_201909122158_RINEX-3_00_HOSTSPOT.zip” is when i use the phone as hotspot to connect to internet. The issue here is the one described in the begining of this thread.
All corrections are send through NTRIP.
When i connect the units to the same wifi netwirk, there is no problem with the corrections send by the Ntrip caster.
@tatiana.andreeva The same thing happened to me with version 2.21.2 so I went back to the stable version. The satellite bars turn on and off, first they go up and then they don’t appear
If you come across this issue once again, could you please send us your logs (raw data log, base corrections log, position log), Full System Report and the screen recording of the issue happening?
