I can state that the speed of 2g is not supported by rs2. this device must have really good gsm internet speed to get fix.
RTCM3 corrections are lightweight, that’s why a 2G network is enough to pass them. However, delays may occur if 2G coverage is weak in your region.
Can you tell me a bit more about the issue you have? Also, please record 10-15 minutes logs where the issue persists and share them with me, so we can investigate it. We’ll need:
- Raw data, position, and correction logs from the rover
- Raw data log from the base
To keep the data private, you can send it to support@emlid.com.
