Hi Luke,
The possibility to select the particular NMEA messages is on our roadmap. However, there’s no ETA. I can notify you when it will be available.
In the meantime, the possible workaround could be to use a 3rd party board to filter out the necessary messages in the NMEA stream. For example, you can check out this thread where @PotatoFarmer shared his experience with it.
