Hi, I work in Puerto Rico and I’m trying to collect points with NAD83(2011) + NAVD88(GEOID18) vertical. 2 weeks ago I put these datums in a protect and took points but now it says Out of CS bound. can someone help me with this I need it for work.
Is the rover icon following you in flow app
Yes, when I try to create a new project it whiny let me collect any point.
“NAD83(2011)”
Exactly which one do you have assigned? It needs to match your region/zone you are in.
UTM ZONE 20N? 19N?
Can u see the images?
I selected only Nad 83(2011)/ Puerto Rico and virgin island. I didn’t select the utm zone.
I will do that now
I did it like this 2 weeks ago and it worked like that.
Not sure… seen this when incorrect coordinate system assigned or in another situation where the rover lost internet connection.
Have you restarted the reciever
I would strongly recommend when this symptom is still showing making a full system report and send it to support@emlid.com
i restarted both recivers ( reach rx & rs2+) but nothing changed.i was looking at the forum and some guys had the same issue due to a update on emlid flow app.
maybe when the next update come it will fix that.
i will send a system report to emlid.
is there any warranty on these equipment? because i been having multiple problems with the reach rx. it disconects from the phone some times and in stake out it will be off sometime.Is there any way i can get the reach rx covered on warranty and mabe get a new one?
thanks
Ok thanks
