Im assuming most of your user base is in the US (maybe set the default user base to US)
In wpasupplicant.conf
a.) add “” (quotes) around the password I cant seem to get it to work without quotes, and can save a newbie a lot of time and frustrsation
b.) make example password shorter if your editing the default file on the RPi with a keyboard like I am, its just a simple well deserved change so I don’t to hold down backspace for 30 characters or so
Add a /etc/apt/preferences file such that the default emlid/raspbian repos will not be overwritten if additional repos are added (sort of a failsafe to help prevent breaking kernel)
*side note- Im not exactly sure how you’ve gotten the emlid links to work as it is not listed in the sources?
Create a script to easily add & remove PIXEL desktop, while it is clear this OS is meant to run headless, in many cases installing the desktop for experimenting and easier editing. Then having a way to uninstall it could be very. This could be very useful to some users, or save others a lot of frustration if they are not familiar with linux (helps to streamline/mainstream setup of your product)
Add sources for gstreamer (I don’t think these are included?) I might be wrong
Install iproute2 by default (technically ifconfig is deprecated) and especially with the interest in using wifi for different functions having users more familiar with iproute2 would not be bad. It’s not hard to install by yourself but would just be a nice touch.
RESEARCHING AND WILL UPDATE SOON
