Hi, people.
I can’t make Oplink Mini Air Ground Telemetry radio works with Navio2. I’m running APM Planner 2 over Ubuntu 16. The ground radio is connected to the USB port, light is on (pink and green), but the serial device is not detected in APM. Any idea? Does someone use it with Navio2?
Hi!
Do you see the ttyUSB device when it’s plugged? To check please run the following command in the terminal:
ls /dev/ttyUSB*
