Hi ,I used reach RTK but I still can not get 5 satellites and GPS signal SNR>45 at many places such as rooftop of high building with no obstacles blocking the skyview,top of the hill etc.
So I only get single mode
how can I enhence GPS SNR or decrease Reach SNR condition
Please provide a picture of your setup showing your ground planes, and q screenshot of ReachView with satellite status.
Thank you for your prompt reply.
I change ground plane and get below better SNR,but…
But mode still at “-” or “single” ,do not change to float or fix mode
how can I do?
I changed integer ambiguity validation threshold to 1.5 other parameters use default
Which version of ReachView do you have? Please provide a screenshot of your base settings.
You should set the approximate base position (lat, lon, height), this is why you only had single mode.
