I successfully tried the Servo example from your github repository (with my brushless motors, but I guess this should not matter?).
But there seem to be only 2 channels for PWM, but my quad obviosuly has 4 motors (Ardupilot can control all 4 motors).
I get the error Can't init channel 2 (from PWM.cpp:18).
Checking the filesystem it shows only 2 pwm channels:
ls /sys/class/pwm/pwmchip0
device export npwm power pwm0 pwm1 subsystem uevent unexport
ls /sys/class/pwm/
pwmchip0
All 14 Navio2’s servo rail pins can be used to output the PWM signal.
If you want to control PWM pins you can access them using GPIO. We have an example of use in our documentation.
You can also check Navio2’s examples. There is also information in the description regarding the means of accessing pins using Python and C++. They might be of help to you.
May I ask, were you making your own autopilot or creating control scripts when you’ve faced this issue?
Normally, all the pins should be present in the pwmchip0 directory. It’s rather hard to say what caused them to vanish on your previous boot without knowing your full setup. However, if they do appear there now, everything should work just fine.
If the issue will show up once again and you won’t be able to operate PWMs, please, let us know.
