Hi, I have a problem with one of my RS+ units, where it simply just won’t see any wifi’s.
I have 2 units. One works perfectly (one that recently replaced due to another an seemingly unrelated WiFi issues), but the other just won’t see or connect to any WiFi. The list of wifi’s is simply empty, but on the other unit I see my WiFi’s and the neighbors just fine.
Here is what I have tried so far, all without any success:
reflashing the unit (2.14).
checking all password
connecting to a auto-switching 5g/2.4g network
connecting “pure” 2.4 and 5g networks.
-checked all passwords for the WiFi’s.
connecting to my phone WiFi hotspot:
It seems like it is trying to connect, but for some unknown reason never succeeds. On my iPhone hotspot, the blue hotspot comes up for 1-2 seconds while the unit tries to connect, and disappears again.
Manually? Master reset? Not sure what you mean.
I have reflashed the firmware according to the documentation. That also resets everything, as far as I know.
Not considered a stable firmware, and no way to go back to 2.14 according to the docs.
I would also be confident that @dmitriy.ershov would have told me if this was already solved in 2.15.
From my experience 2.15 has been solid, but my use-case may be different. Not being able to flash back is very odd and unfortunate. If you have done everything mentioned in this thread today I would be almost certain that it is a hardware fault. I don’t think there’s anything else you can try with a simple function as this. I mean consumer Wi-Fi has been around for over 25 years. Does that make you feel old? It does me.
