One of my Reach RS units purchased in September 2017 is having issues booting up.
The on switch appears not to function so I can’t hard reset or reflash the unit.
Only way to turn it on seams to be by inserting the usb cable and that has only worked twice. Last time it started I was unable to connect via either hotspot or saved network. It remained stuck in this mode (pwr light and network light flashing) until it powered of with a flat battery.
.The time before the battery indications all looked good both when charging and disconnected from the charger. I was able to shut it down then by using the wifi interface controls.
Any tips or anybody overcome similar problems. I expect that battery may have been over discharged and a replacement might be my solution but more likely a switch problem.
I
am hoping that I can get it to restart after charging and move straight into a reflash.
Any help appreciated Thanks Ed
