Offset for non Emlid Antenna
Hi All,
I have just purchased a Harxon HX-CSX627A to use with with the M2 as a semi-permanent static base.
The antenna has a NGS calibration [Antenna Calibrations (noaa.gov)] https://www.ngs.noaa.gov/ANTCAL/#)
When setting the antenna over a known base, what offset would i use to account for the L1/L2 phase centre offset over the ARP?
50mm (5cm)
For my reference, and if i ever use other antennas, how did you find that?
I couldn’t find any documentation from Harxon, so I compared where NGS shows the offset for a known antenna (RS2) in their test result, and then looked for the figure in the same place for the Harxon HX-CSX627A.
I’m not absolutely positive, but it looks reasonable.
Thank you, i can see printed on the antenna it says L2 47.8mm and L1 54mm
there ya go, confirmed!
So it is just the difference between these two?
It is somewhere in between, not necessarily exactly the difference. I would use what NGS determined unless you are only going to use only one band or the other.
