- Firmware image and ReachView version. v2.22.0
- Detailed problem description. How does observed behavior differ from the expected one?
First time performing an RTK survey with 2 x RS2 receivers.
My problem is that I did NOT record (write down or download) the Base LLH at the time of survey. Because I do not have the Base LLH used at the time of survey I cannot translate my survey to my base PPP coordinates.
Also I did NOT log RTCM data on the rover.
I DO have RINEX and LLH log files for the base, but I assume that the positions in these files will not perfectly match Base Coordinate generated by the Average Single method at the time of base startup.
Absolute Accuracy is important to me and I was planning on using the base RINEX data to process to via PPP to obtain an accurate base location and then adjust my RTK survey based on the difference between the Average Single Base LLH and the PPP Base LLH.
Any ideas on how I can salvage my survey would be appreciated.
Kind Regards,
Luke
