Hello everybody
First my English is not good so try to understand me please
I have 2 units rs+
And i want use app (nuwa) but it give me only 5 point
I want change LoRa antenna cuz it broke can i use wifi router antenna?
Hello @srv.islamabdallah ,
Although there is a connector on Edison Board, you shouldn’t connect an external wifi antenna. The internal antenna versions have a u.FL connector on the board, but it is only used as a manufacturing test point. Do not connect an external antenna to a board with an internal antenna.
Hope it helps!
Best regards,
Slava
Hi Islam,
I’d recommend getting new LoRa antenna from our store. There are two options:
LoRa antenna for RS+ or LoRa antenna for RS2.
Most likely you won’t be able to use a Wi-Fi router antenna as it works in a different frequency range.
As for Nuwa app, I’m afraid I won’t be of much help here. Please check with the developer on the issue with saving points.
It’s been a while since the last post in this thread, but I’m here to let you know that we now have the ReachView 3 app with many useful features! It allows you to work with different coordinates system within your project. It’s more convenient to collect the points with a user-friendly interface. Don’t hesitate to create a new topic if you have any questions or requests about ReachView 3.
