Make sure the correction stream you are mounted to is RTCM3. This has caught me a couple of times after a reset where our provider defaults to 2.3 when we first login so I have to manually choose the next one down for 3.1.
I’ve checked the details you’ve shared with us via email. As I see from the screenshot, your Reach M2 doesn’t calculate a solution. Can you please place the unit under an open sky, wait until it calculates at least a Single solution, and check if it can receive corrections after that?
Also, please ensure that the Internet connection is stable. You can connect your Reach M2 to another Wi-Fi network to double-check it’s not an issue.
Hi Kseniia,
Indeed it was solved once we placed the reach M2 in an open sky. I was naively expecting to be able to setup this indoor. Thanks for your answer.
