NTRIP Timeout on iOS Hotspot - Reach RS
Hi all, I wonder if anyone else is suffering from a similar problem.
I am fully credentialed with the euref-ip.net NTRIP caster, and I can connect my Reach RS to the caster with no problem through my home wifi network, and currently have 19 sats coming in as corrections.
But when I try to go “mobile”, that is, by connecting my reach to my iPhone’s Hotspot Network, I am unable to download corrections, but I can check for updates etc, so I have some connectivity. The status on the “Correction Input” page says "Connected to Euref-ip.net, followed after a few seconds with “Timeout”. I’m guessing that it is clearly to do with my iPhone (5S, running latest iOS11).
Anyone had similar issues/suggestions of things to try? I have tried all the ports that the NTRIP caster is on (80, 2101) with the same result.
Thanks
Andy
  1. Firmware image and ReachView version.
    ReachView version 2.10.0
  2. [System report]
Report 1 - Connected to Home wifi.
Simple system report
app version: 2.10.0-r0
'wifi_status, interface: wlan0':
- Client state
- IP address: 192.168.1.162
 mac address: fc:db:b3:9a:f9:62
 ssid: BTHomeHub2-CNZQ
base mode:
 base coordinates:
   accumulation: '2'
   antenna offset:
     east: '0'
     north: '0'
     up: '0'
   coordinates:
   - '0'
   - '0'
   - '0'
   format: llh
   mode: single-and-hold
 output:
   enabled: true
   format: rtcm3
   path: lora
   type: lora
 rtcm3 messages:
   '1002':
     enabled: true
     frequency: '1'
   '1006':
     enabled: true
     frequency: '0.1'
   '1008':
     enabled: false
     frequency: '1'
   '1010':
     enabled: true
     frequency: '1'
   '1019':
     enabled: false
     frequency: '1'
   '1020':
     enabled: false
     frequency: '1'
   '1097':
     enabled: false
     frequency: '1'
   '1107':
     enabled: false
     frequency: '1'
   '1117':
     enabled: false
     frequency: '1'
   '1127':
     enabled: false
     frequency: '1'
bluetooth:
 discoverable: false
 enabled: false
 pin: '***'
correction input:
 input2:
   enabled: true
   format: rtcm3
   path: andymarine:***@euref-ip.net:2101/DARE00GBR0
   send position to base: 'off'
   type: ntripcli
 input3:
   enabled: false
   format: rtcm3
   path: :9028
   type: tcpsvr
logging:
 base:
   format: RTCM3
   started: true
   version: null
 correction:
   format: RTCM3
   started: true
   version: null
 interval: 24
 overwrite: true
 raw:
   format: UBX
   started: true
   version: null
 solution:
   format: LLH
   started: true
   version: null
lora:
 air rate: '18.23'
 frequency: 868000
 output power: '20'
position output:
 output1:
   enabled: true
   format: nmea
   path: bluetooth
   type: bluetooth
 output2:
   enabled: true
   format: llh
   path: :2013
   type: tcpsvr
rtk settings:
 elevation mask angle: '15'
 glonass ar mode: 'off'
 gps ar mode: fix-and-hold
 max horizontal acceleration: '1'
 max vertical acceleration: '1'
 positioning mode: kinematic
 positioning systems:
   compass: false
   galileo: true
   glonass: true
   gps: true
   qzs: true
   qzss: true
   sbas: true
 snr mask: '35'
 update rate: '5'
Report 2 -connected to iOS hotspot
- Client state
- IP address: 172.20.10.9
 ssid: Andy's iPhone
base mode:
 base coordinates:
   accumulation: '2'
   antenna offset:
     east: '0'
     north: '0'
     up: '0'
   coordinates:
   - '0'
   - '0'
   - '0'
   format: llh
 output:
   enabled: true
   format: rtcm3
   path: lora
   type: lora
 rtcm3 messages:
   '1002':
     enabled: true
     frequency: '1'
   '1006':
     enabled: true
     frequency: '0.1'
   '1008':
     enabled: false
     frequency: '1'
   '1010':
     enabled: true
     frequency: '1'
   '1019':
     enabled: false
     frequency: '1'
   '1020':
     enabled: false
     frequency: '1'
   '1097':
     enabled: false
     frequency: '1'
   '1107':
     enabled: false
     frequency: '1'
   '1117':
     enabled: false
     frequency: '1'
   '1127':
     enabled: false
     frequency: '1'
bluetooth:
 discoverable: false
 enabled: false
 pin: '***'
correction input:
 input2:
   enabled: true
   format: rtcm3
   type: ntripcli
 input3:
   enabled: false
   format: rtcm3
   path: :9028
   type: tcpsvr
logging:
 base:
   format: RTCM3
   started: true
   version: null
 correction:
   format: RTCM3
   started: true
   version: null
 interval: 24
 overwrite: true
 raw:
   format: UBX
   started: true
   version: null
 solution:
   format: LLH
   started: true
   version: null
lora:
 air rate: '18.23'
 frequency: 868000
 output power: '20'
position output:
 output1:
   enabled: true
   format: nmea
   path: bluetooth
   type: bluetooth
 output2:
   enabled: true
   format: llh
   path: :2013
   type: tcpsvr
rtk settings:
   compass: false
   galileo: true
   glonass: true
   gps: true
   qzs: true
   qzss: true
   sbas: true
 snr mask: '35'
 update rate: '5'
  1. Detailed problem description. How does observed behavior differ from the expected one?
I expect the corrections to not timeout.
  1. Your step by step actions.
See above.
  1. Picture of the setup and connection scheme.
See above.
