Hello, i am using a public provider base. Everything works as expected. Rover and base are comunicating over TCP (internet). I can see both Rover and Base and everything works as expected.
My only problem is i get a very very unstable fix and almost always i am on float, even in really open area.
My baseline from the public ntrip service is 24 KM and when i get a fix i see correction ratio jumping up to a high number, than it starts falling until it reaches areound 10 and it goes to float forever again.
Should i drop my public server and setup my private base? Is 24KM baseline too much?
I hade similar issue, but got fix eventually and not so bad as you got. With relative refrence located nearby with local wifi i got much faster and stable fix. Not sure what causes this behavior wtih vrs. Mine was also 5-10m away.
Did you enable the location feedback from your station? Think mine was set to singel.
